AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Area Command in ACAD 2013
1 REPLY 1
690 Views, 1 Reply
Hi there i have a problem with the area comand in 2013LT as it lets me click  to select the points and create a region, but then when i hiit return to close the command it asks me to select another poin (arc/length/undo)
Command: _MEASUREGEOM
Enter an option [Distance/Radius/Angle/ARea/Volume] <Distance>: _area
Specify first corner point or [Object/Add area/Subtract area/eXit] <Object>:
Specify next point or [Arc/Length/Undo]:
Point or option keyword required.
Cant figure out why it wont give me te area.
thanks
Tags (4)
1 REPLY 1
pendean
Are you using your mouse' right-click button for <enter>?
Does the problem occur if you actually hit the <enter> key on the keyboard?
What if your right-click and select EXIT while in the command?
”Boost
