AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
architectural catalogs in MEP 2013
3 REPLIES 3
barry.doherty
700 Views, 3 Replies
I have just upgraded to MEP 2013 from 2012 and have just gone to use the default catalogs in content browser only to find the aec ones missing does anyone know how to install them.
Regards
Brian
3 REPLIES 3
Keith.Brown
in reply to: barry.doherty
Go into your windows control panel and choose uninstall a program.  Then select Autocad MEP 2013 and choose change.  This will bring up the installer and allow you to install compenents that were not installed the first time around. Choose Add/Remove content and make sure to check the architectural compenents.  You might need your original installation media at this step.  I am not sure though.
Hope this helps and good luck!
You will need the original installation media to install the Architectural content packs, yes.
Joshua
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Joshua Benoist, PE
Senior Premium Services Specialist
Global Services
Autodesk, Inc.
Following up.  Did the above help?
Joshua
Joshua Benoist, PE
Global Services
Autodesk, Inc.
”Boost
