AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Accessing xref via .NET
4 REPLIES 4
Anton_O
1015 Views, 4 Replies
Hi.
Is there any way to access xref dwg and make some changes, without opening it? My approach is to make some sort of “Edit referenced property set data”. I’m able to get data from xref, but not to make or save changes to it.
Can someone advise some classes for that problem? Any sample code would be appreciated. I’m using C#.
Thanks.
4 REPLIES 4
Martin__Schmid
in reply to: Anton_O
you'd probably be better off posting in the AutoCAD .NET forum:
http://discussion.autodesk.com/forums/forum.jspa?forumID=152
However, I'll take a stab:
Get the path from the PathName property from the BlockTableRecord for the xref.
Create a Database:
Database db = new Database();
db.ReadDwgFile(); // need to use proper overload to pass in the path
edit the db like any other, then save its changes and dispose of it.
There is:
Autodesk.AutoCAD.DatabaseServices.Database.ReloadXrefs(Autodesk.AutoCAD.DatabaseServices.ObjectIdCollection);
which you'd probably pass in an ObjectIdCollection of all the blocktablerecord objectids that you need to reload, in this case, it would only be the one that you are modifying. You might need to then tell the view to regen.
Martin Schmid
Product Line Manager
Mechanical Detailing and Electrical Design
Architecture, Engineering, and Construction
Autodesk, Inc.
Anton_O
Thanks for answering, Martin. You’re helping me, again 🙂
I’ll try to post such problems in .NET forum ). But to end current thread:
When I try to save referenced database I get exception “eFileInternalErr”. Database is loaded like this : xrefDb.ReadDwgFile(fileName, FileOpenMode.OpenForReadAndWriteNoShare, true, "")
Also I’ve tried:
xrefDb.ReadDwgFile(fileName, System.IO.FileShare.Write, true, ""), but then exception is thrown when reading dwg file “eInvalidInput”.
And calling Autodesk.AutoCAD.DatabaseServices.Database.ReloadXrefs(Autodesk.AutoCAD.DatabaseServices.ObjectIdCollection) throws exception of “eWrongObjectType”. ObjectIdCollection passed into ReloadXrefs contains only ObjectId of xref.
Can you suggest something?
Edited by: Anton_O on May 21, 2009 8:19 AM
Martin__Schmid
refer to the attached sample
Martin Schmid
Autodesk, Inc.
Anton_O
I was getting xref like BlockReference, instead of BlockTableRecord. That seems to be the cause of those exceptions.
Thanks again. Everything works fine now.
”Boost
