I am jsut starting to use MEP 2012 and am trying to figure out how to set it to default to use 1-1/2x radius 4 gore elbow for my round elbows. In 2011 there was a drop down box that isn't there in 2012. Thanks for your help!
Solved by Joshua.Benoist. Go to Solution.
Made you an image that steps you thru to the Duct Routing Preferences.
http://screencast.com/t/h4aXet8in
Joshua
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Wanted to follow up. Did that image help?
Joshua
I never got a video but the image helped. I sent a reply thru my email, it must not have gone thru. I was asking if once I set that the the 1.5 radius elbow will it stay that way till i change it or do I have to do this every time?
It will stay that way till you change it. However, you could copy the routing preference. Give it an applicable name. Change the fitting in the copied routing preference. Then as you draw new duct, change the routing preference selection on the property palette.
Joshua
