Well, I have gas duct heater that is neither a motor, nor a receptacle, nor
an electric heater. It needs power supply to run igniter and controls, and
there is no specific electrical symbol fitting this particular piece of
equipment, available. Therefore I decided to put a junction box there with
indication: connect DF-1 here. JB as is has no load, but you may change its
property from general to 120v power, which is exactly what is needed. Then
other fields show up and you may write in or select the circuit number,
number of poles, and the load. The only problem is that the load data is not
read by circuit manager, nor by circuit report. The load is still there, but
the panel shows 0 VA and same shows the circuit report.
sp
"jason martin [Autodesk]" wrote in message
news:3fe1a936_7@statler...
> Hi Slawomir -
> What you've said is a bit confusing. You'll need to (probably create a new
> device style then) edit the device style and change the connector system
> type from general to Power & Lighting. Then you can assign voltage, load,
> of Poles and the circuit should reflect the load that you have specified.
> You could also add a second device to the circuit, put it on a "special"
> layer (or just place it "off-screen") and the load will be added to the
> circuit.
> jason
> "Slawomir Popiel" wrote in message
> news:3fe13858$1_6@statler...
> > Hi
> > I need to put a "dummy" load. I've inserted a junction box then I've
> changed
> > the property from general to 120V power and I've set a load value. Still
> the
> > panel schedule, circuit information and circuit report shows this
circuit
> > shows 0 VA load.
> > can anybody help, please?
> > sp
