And where in the white paper does it address the requirement for sloping pipes? If your fittings don't take this into account (tees and elbows, regardless of connection type), you're spending a lot of time developing a system that doesn't address a fundamental requirement.
The product is called 'Autodesk Building Systems', not 'Autodesk Piping'. And a piping module that can't be used to draw 3D building hydraulics does the easy stuff OK, and the hard stuff not-at-all. It's the sloping piping that needs the coordination, not the pressurized piping. You can run pressurized piping in a spiral for all that it matters.
It's not like anyone is going to do any material costings from an ABS model, when your design hasn't factored in the location of your waste piping. What will happen when the building contractor runs into a waste pipe that is in his way while he's laying his refrigeration piping? He'll take one look at it and realise he can't be moving the waste pipe. It doesn't flow up-hill after all. What he'll do (while swearing under his breath) is re-route the pressurized piping around the waste piping, thus throwing all of your precious ABS material calculations out the door. More pipe, and more fittings, and the fact is, he more-than-likely won't even tell you what he's done.
Read that very carefully guys... because it's a fundamental issue, and having read that white paper you've just written, it isn't even on the radar.
