AutoCAD MEP General Discussion
Distinguished Contributor
tarmbruster
Message 1 of 3 (124 Views)
3-Way Diffusers
124 Views, 2 Replies
07-23-2003 11:30 PM
How do I so a 3-way and 2-Way Diffusers in plan view. Normally I would hatch the 1 or 2 sides of the diffuser that is not being used, But I can't hatch MV Parts.
The only option I can think of without creating a new MVpart is to draw a pline ofer the MVpart then hatch the object. Any other options?
Toma1379
A+E Group
*[Autodesk], Peter Terwilliger
Message 2 of 3 (124 Views)
Re: 3-Way Diffusers
07-24-2003 12:23 AM in reply to: tarmbruster
Hi Toma -
You will need to hatch the view block used in the
plan view.  An example of what you want to do is contained in the 18 x 18
Square Louver Face Ceiling Diffuser.  It uses hatched blocks in for the
schematic blocks.
Come to think of it, the ABS 3 IsoSchematic display
config (which was the only display configuration that used the symbol view) may
have been removed from ABS 2004 templates for some reason.  It enabled you
to see everything in one line with the MvParts as symbols - essentially a
to-scale isometric.  You can recreate it easily enough by changing the
Display Set "ABS Floor Plan 1 Line" setting for MvParts from "2 Line" to
"Schematic", then view everything in the Display configuration ABS Floor
1-Line.
I hope this helps!
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
How
Toma1379
A+E Group
*[Autodesk], jason martin
Message 3 of 3 (124 Views)
Re:
07-24-2003 12:25 AM in reply to: tarmbruster
You could also use flow arrows, with a custom block so that you could show
the same part as either a 2 way or 3 way flow. To do this right click the
part and go to MvPartProperties -> Flow tab.
jason
"Peter Terwilliger [Autodesk]" wrote in
message news:34A742F4A0504F6F5E7241B0CE8E651D@in.WebX.maYIadrTaRb...
> Hi Toma -
> You will need to hatch the view block used in the plan view. An example
of what you want to do is contained in the 18 x 18 Square Louver Face
Ceiling Diffuser. It uses hatched blocks in for the schematic blocks.
> Come to think of it, the ABS 3 IsoSchematic display config (which was the
only display configuration that used the symbol view) may have been removed
from ABS 2004 templates for some reason. It enabled you to see everything
in one line with the MvParts as symbols - essentially a to-scale isometric.
You can recreate it easily enough by changing the Display Set "ABS Floor
Plan 1 Line" setting for MvParts from "2 Line" to "Schematic", then view
everything in the Display configuration ABS Floor 1-Line.
> I hope this helps!
> "Toma1379" wrote in message
news:f17a7f5.-1@WebX.maYIadrTaRb...
hatch MV Parts.
> Toma1379
> A+E Group
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
