Show only
Search instead for
Is there an answer for this? To clarify...when using hanger styles in MEP they work as intended and appear solid when viewing in realistic or shaded. However, when this drawing is viewed in Navisworks the hanger style becomes wireframe and the solid object is lost. This makes its it painful to run clashes against.
Everything worked fine out of the box. Do you have 2013 by chance to check to see if it's just the version or if it has something to do with how you made yours?
Shawn B.
| To help improve Autodesk Products, please Click Here to Vote for ideas and submit your own.
