AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
2 blade boat propeller in 3D
3 REPLIES 3
2145 Views, 3 Replies
I'm trying to model a 2 blade prop and could use some tips.  I've tried using Helix with a 3/4 turn and a Sweep with a clam shell polyline  (ie; ()  ) and it is close, but not quite.  This is just for looks in a 3D model, not for manufacture.
Dutch
3 REPLIES 3
This may not work better than Sweep, but you may want to try the Loft command instead.  You could place a series of polyline shapes in sequence and use the guidelines to refine the appearance of your model.
ductman,
Thanks for the reply.  I ended up using a thin oblong spline and then Sweep with a 80 degree twist.  I then used the original oblong spline, scaled it down a bit and then used Loft to make the blade end.  I mirrored the blade and placed it on a 3D cylinder.  Came out pretty good, at least for what I needed anyway.
Dutch
You're welcome...excellent job on the prop!
”Boost
