A quick answer.
You need to use Project Manager.
So you can create pipe or duct for each level in construct drawing. Do the same thing with Archi and create a view drawing with what you want to see.
See the screen of project with 17 floor.
Like that, you don't need to create wall and floor. Just add level archi and duct in one view 🙂
Hi Cristophe,
Thanks for your answer, it clarifies a lot what we should be doing.
We were following our usual workflow from Autocad Plant 3D but it seems that we require something different for Autocad MEP.
Do you design in 3D all you MEP specialties? That seems really helpful for integration.
Regards.
Eloy Ruiz
I used to make 3D drawings for Duct because i can't provide list of pieces to order directly.
For heating, it is according the difficulty of project. Often i use 2D pipe because it's quicker.
But i prefer 3D because it's more "fun" and realistic.
I used schematic for plumb.
You need to learn how to use project manager if you have several level. It's important to avoid some mistakes.
I think you can use it for 3 or 4 floors building. For less, you just loose time.
