AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
What happened to select device option in MEP 2009?
2 REPLIES 2
260 Views, 2 Replies
I typed "select device" in the help information for AutoCAD 2009 MEP but it is not updated with the 2009 properties layout, it looks identical to the MEP 2008 properties layout. The select device option is not showing up on MEP 2009 as it did in 2008 (see attached pdf)
Any information you have directly relating to this issue would be greatly appreciated!
Zach Edited by: zachary178 on Feb 12, 2009 10:11 AM
2 REPLIES 2
tobysmith
The "select" button was too important to remain isolated as a small pick button. In the 2009 product, you now just simply click on the style image in the Properties Palette to launch the Style dialog (see attached image).
Hope that helps,
Toby Smith, PE, LEED AP
AutoCAD MEP Product Manager
Mr. Smith,
Thanks for the reply. I use this feature on a regular basis and agree it was hidden well in MEP 2008 considering it's functionality. Your solution works great!
Sincerly,
Zach
”Boost
