I'd like to create 'Gripple' using an MEP Pipe object.
In Properties Palette typically you select the pipe size from the Nominal size drop down. However, it has been dictated that LUPREC is set to 3 (or 1/8").
Gripple diameter however is 3/64, 5/64, 1/8. 3/16 and 1/4... when LUPREC is set to 3... they show up as 0, 1/8, 1/8, 1/4 and 1/4.
In the definition of this 'Gripple' pipe definition... wouldn't it be possible to pull this from a list of strings, or #1 Gripple, #2 Gripple, #3 Gripple... etc.???
Hey Hutch...what the heck is a "gripple" and LUPREC?
David A. Butts
Engineering Technology Manager - Gannett Fleming
Revit Certified Professional/Autodesk Certified Instructor
Revit, AutoCAD Architecture, MEP, Plant 3D, BIM Collaborate Pro Subject Matter Expert
Could you just use a list definition parameter for the predefined sizes, and then associate it with the pipe diameters?
David A. Butts
The System Variables LUNITS and LUPREC are the variables that store the current Length Type and Precision settings.
Just create a grippleAdd LISP command that sets the precision, then starts the pipeAdd command, then after the command completion returns the precision to its normal value.
Not sure if that violates your LUPREC policy or not.
