Is there any way to move multiple conduts and keep them connected to the other conduits in the run.
For example I will draw 8 conduits with Parrallel conduit command only to find out later there is a door frame in that spot.
I want to be able to slide over the whole pipe run with out clicking on each conduits center grip?
I tried multiple different ways for a work around but they all seem to be different ways of doing a move command which doesn't keep the conduit connected back at the last bend on the run.
In your example (open ended conduit run or conduit run with 90 degree elbows at both ends) I would use the stretch command with a crossing window selection. If angles are involved, you have to grip select each elbow and move it. I too wish there were specialized tools available to edit conduit runs.
JMV
