Hi All,
Is there any way to review a list of hidden object and select some of the hidden objects which I would like to unhide?
I use AutoCAD MEP 2015.
Solved by ВeekeeCZ. Go to Solution.
Hidden because you have a drawing drawn by newer version of MEP ??
If that's true, probably need to get new version of MEP Objects Enabler to see them.
If they are hidden using ISOLATEOBJECTS or HIDEOBJECTS command, then you can try this LISP routine. I shows all the objects, the you can pick the ones to NOT hide AGAIN.
(defun c:UnhideObjects ( / ss sadd) (command "_.ZOOM" "_All") (setq ss (ssget "_C" (getvar 'EXTMIN) (getvar 'EXTMAX))) (command "_.ZOOM" "_P") (command "_UNISOLATEOBJECTS") (if (setq sadd (ssget)) (command "_.ISOLATEOBJECTS" ss sadd "") (command "_.ISOLATEOBJECTS" ss "")) (princ) )
Hidden by 'HIDEO' command. The thing is that quite often I use this command to hide objects which are on the same layer and when I want to 'unhide', all hidden objects appear. I was wondering whether it is possible to show onle some of the hidden objects.
HIDEO command? Or is that a typo, no such command in plain AutoCAD where you are posting. If it's in MEP you need to be asking in that forum then.
HIDEO is a short version of HIDEOBJECTS in my AutoCAD.
I have no problem with hidding or unhidding objects, I was just curious whether it is possible to select somehow objects which I would like to unhide at the moment as the command UNHIDE shows all hidden objects.
