AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Why are leaders and their associated text not linked together?
2 REPLIES 2
shanman56
1359 Views, 2 Replies
I am having more frustration with basics of the new 2015 system functions.
When I used to create a leader, it acted as ONE UNIT and all you had to do was select the text or the leader/arrow itself and copy/mirror/move and then the leader would follow the text and stay pointed towards the original location.
NOW the leaders act as TWO separate entities that don't work together at all.
I have tried DIMASSOC, but this does not change the functionality of leaders in the way I need them to.
Can someone please help with the specific command used to Return me to the original associative functions?
Thank you.
Shan
2 REPLIES 2
steve216586
in reply to: shanman56
The difference in performance of leader mod is basically the characteristics between MLEADER and QLEADER. MLEADER performs as you desire, as a unit. QLEADER is two separate entities between text and leader.
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
acwtzwegers
What happens if you use the AMNOTE functionality?
”Boost
