On Layer Manager can't see VP Color and VP Linetype see picture can same one help Thank.
Solved by Sridhar-Autodesk. Go to Solution.
Please use Layer command in the layout to see VP Color and VP LT. What I see from the screenshot you attached is Mechanical layer manager (AMLAYER).
Ribbon icons will invoke AMLayer command.
FYI: AutoCAD Mechanical assigns automatic layer color for viewports.
