you guys have helped alot getting past the 2015 issues. I have another, i set up my ddim styles as i always have for years. i get strange dim styles. I have also noticed that the dim ribbon acts on its own. So i guess it has something to do with it, some kind of dimentional conflict between dimstyles. anyone know how to destroy this "STANDARD$0" i cant seem to make it go away in the 3 or 4 minutes a day i have to fix autocad issues?
THANKS,
AutoCAD Mechanical used to be a 3rd party plug in for AuoCAD around 1992 called "genius". Since Autodesk bought it to create this vertical, it has not really been updated - only bug fixed when it became too unstable.
The result is that any feature introduced after that time is not or barely supported - including annotative dimensioning (and anything else to do with paper space).
A fix that has been hacked together (probably to keep the genius system from completely falling appart) is a reactor that copies annotative dimension styles to $0, $1 etc ones.
So what yoiu can do:
thanks for the responce. I think i will just not name any dimstyle "standard" it
seems to help
