AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
What is the equivelant of UG/NX "Sketch" Mode?
2 REPLIES 2
524 Views, 2 Replies
In the past, I've worked with Siemens Unigraphic NX software, but right now I only have AutoCAD 2010 Mechanical at my disposal.  In Unigraphics, I was able to just go into a 2D sketch, make the basic shape of what I wanted, then add dimensions and constraints to the sketch and the lines would adjust accordingly.  It seems like in AutoCAD that once I create a line, it is fixed at the length I created it at.  Is there any mode I can use that will allow me to make rough sketches, and then use dimensions and constraints to set the appropriate lengths?
2 REPLIES 2
michaelsu
Try commands _GeomConstraint and _DimConstraint.
Also, if you use ribbon, you can find more functions in Parametric ribbon tab.
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
Thanks, associative dimensioning seems to do the trick!
”Boost
