AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
What can AMSHIDE not hide?
2 REPLIES 2
pete592
521 Views, 2 Replies
Does anyone know of a reference that clarifies what you can and cannot hide with the AMSHIDE command?
I have two different entities in the attached file.  AMSHIDE only recognizes the one on the right, and I don't know what distinguishes the block on the left that deems it "disallowed."
Thanks in advance for any help.
Pete
2 REPLIES 2
Sridhar-Autodesk
in reply to: pete592
Hi, Pete
The block on the left is a dynamic block.  Dynamic blocks are not recognized in AMSHIDE command.  You may use AM2DHIDE command to hide dynamic blocks.
Hope this helps
Sridhar Subramani
Senior Product Owner
pete592
in reply to: Sridhar-Autodesk
Excellent.  Thank you.
”Boost
