Does anyone know of a reference that clarifies what you can and cannot hide with the AMSHIDE command?
I have two different entities in the attached file. AMSHIDE only recognizes the one on the right, and I don't know what distinguishes the block on the left that deems it "disallowed."
Thanks in advance for any help.
Pete
Solved by Sridhar-Autodesk. Go to Solution.
Hi, Pete
The block on the left is a dynamic block. Dynamic blocks are not recognized in AMSHIDE command. You may use AM2DHIDE command to hide dynamic blocks.
Hope this helps
