Again in Viewbase Drawing Views, is there a way to break the 'alignment' of a detail view, to be able to locate the Detail View anywhere on the Drawing sheet?
Refer to attached screen shot for an example....
Currently, it seems to sit directly under the parent view the Detail is taken from...and I would like to group all the details in available blank areas of the sheet.
This would be preferable.....
Ideas or suggestions anyone?
Cheers.
Solved by Sridhar-Autodesk. Go to Solution.
Hi
Unlike Projected views, Detail views can be placed anywhere in the drawing. Can you try to move the detail view using Grips?
If this is not working, would it be possible to attach the drawing or send to sridharDOTsubramaniATautodeskDOTcom
