AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Viewbase - Break Detail View alignment
2 REPLIES 2
david.penney00
959 Views, 2 Replies
Again in Viewbase Drawing Views, is there a way to break the 'alignment' of a detail view, to be able to locate the Detail View anywhere on the Drawing sheet?
Refer to attached screen shot for an example....
Currently, it seems to sit directly under the parent view the Detail is taken from...and I would like to group all the details in available blank areas of the sheet.
This would be preferable.....
Ideas or suggestions anyone?
Cheers.
2 REPLIES 2
Hi
Unlike Projected views, Detail views can be placed anywhere in the drawing.  Can you try to move the detail view using Grips?
If this is not working, would it be possible to attach the drawing or send to sridharDOTsubramaniATautodeskDOTcom
Sridhar Subramani
Senior Product Owner
Thanks Sridhar,
Your little video, was very helpful.
Cheers.
”Boost
