AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Unknown command/unhandled exception
4 REPLIES 4
jedenton
416 Views, 4 Replies
Express tools are all having 'unknown command' in command line,,
Orbit tools are all having 'unhandled exception-access violation..
acadmech2010, everything else works...do I need to re-install?
4 REPLIES 4
Steve_Bessette
in reply to: jedenton
I believe the information you are looking for can be found on the following link: http://forums.autodesk.com/t5/AutoCAD-Mechanical/EXPRESS-TOOLS-don-t-work/m-p/2976138/highlight/true...
You may want to run a repair on your product to repair this issue.
Let me know if this resolves your inquiry.
Steve Bessette
Support Specialist
Product Support
jedenton
in reply to: Steve_Bessette
updated graphics driver fixed the unhandled exception ,,still have unknown command from express tools
jedenton
installed express tools thru add features,,,loaded the .cui files and made sure support file path is correct,,,,still have unknown command for express tools.....any ideas????
jedenton
steve,
 that did not work,,however apploaded two .fas files fixed the problem, however have to appload everytime opening a drawing or application...any idea on how to fix this?
”Boost
