AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
unhandled access violation reading 0x0000 exception at 741bfeh
8 REPLIES 8
Message 1 of 9
6234 Views, 8 Replies
autocad mechanical error msg : unhandled access violation reading 0x0000 exception at 741bfeh
8 REPLIES 8
Message 2 of 9
michaelsu
May I request more information about the issue?
From the snapshot, it seems you launched AutoCAD 2013 and it crashed during startup? Any steps to reproduce this issue?
Are you using Factory design suite and use classic workspace?We have a known issue there and are working on the fix.
http://forums.autodesk.com/t5/AutoCAD-Mechanical/AutoCAD-Mechanical-2013-classic-view-fatal-error/td...
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
Message 3 of 9
In detail, first i open autocad mech for the first time with a profile and it works fine i setup all my arrangement of autocad (including using the classic mode) and the next day, i try to open it again and the same error I mention in my last post happens. We tried many different profile and computer and the exact same thing happpens every time.
Message 4 of 9
Somthing new just happened, i get the same problem now with architecture:
FATAL ERROR: Unhandled Acces Violation Reading 0x0000 Exception at 2a996eh
Message 5 of 9
michaelsu
May I know did you install AutoCAD Mechanical or Architecture from any suites products if so can you please let us know the suite details?
Also, could you please send me one of your sample profile to investigate the issue? After the crash, did you send the report and fill in your email address and comment? Please do so if you haven't.
Thanks.
Michael Su
SQA Engineer
Message 6 of 9
Our mechanical and architecture versions of autocad comes from the pacage
''autodesk factory design suite premium 2013''.
The company won't allow me to send you an example of our profile, but what i can tell you is that we tried on a computer that had all the administrator right. And yes i sent a report with my comments but i can do it again if you wish.
Message 7 of 9
Since our last reply there was no answer from your side, are you still trying to figure out the problem or we were forgotten?
Message 8 of 9
michaelsu
Please try the service pack SP1 and see if the issue is gone.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19817524&linkID=15639656
Thanks.
Michael Su
SQA Engineer
Message 9 of 9
Having this same FATAL ERROR while trying to open AutoCAD family of programs which were installed as part of the Product Design Suite Ultimate. Specifically: AutoCAD, + Mechanical, + Electrical, + an error when attempting to load a DWG file into Inventor.
”Boost
