AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Undocumented variable ACMPROFILE
1 REPLY 1
zakaronius
520 Views, 1 Reply
Anyone know what ACMPROFILE controls?  Its not in HELP and i found nothing via Google nor the forums search bar.
1 REPLY 1
Steve_Bessette
in reply to: zakaronius
The ACMPROFILE system variable indicates if the current profile is an AutoCAD Mechanical (ACM) profile or not.
ACMPROFILE = 1, indicates that the current profile is an ACM profile
ACMPRIFOLE = 0, indicates that the current profile is not an ACM profile
This is only an indication and does not enact a switch from an ACM profile to a non ACM profile.
If this resolves your inquiry, please check "Accept as Solution".
Steve Bessette
Support Specialist
Product Support
Autodesk, Inc.
”Boost
