I have read all the other post have tried all they said but still no luck loading acetutil.arx . All things look good but whenever I go load app and find file tell it to load FAIL unable to load acetutil.arx.
Yes uninstalled and reinstalled 3 times no luck
did the cui load then the load app.
Autodesk how come you always have issues with this. started back on 2004 or maybe 2002 why can't you get this to work?
P.S.
Need help today not a week from now, autodesk.
And one other thing support should be free if you can't get things to work right out of the box.
Thanks autodesk just got my butt chewed out for not having work done..
Thank you very much........
Think you can jump in before friday is over? customer is waiting for drawings........
Please try following steps:
Hope this helps
Everything is there the menu , path, folder everything. When I go to appload iand try to load it in the error window it says unable to load the arx. I have uninstalled and reinstalled it 5 times now it installs the express tools everytime but when I start it an error massage pops up and says unable to load express tools. the menu is there but not one command works. The path is there. I followed the path in explorer and all files are there. Not sure but I'm about to uninstall again.................
Thanks for trying...
God I hope this new install works customer not happy he did not have drawings this morning....
Since you have tried uninstall many times, if you get a chance to uninstall again, you may want to try steps from the following link
http://support.autodesk.com/getdoc.asp?id=TS45252
