AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Turn off Annotation Scaling Message box.
5 REPLIES 5
sast
2590 Views, 5 Replies
When i open a drawing Annotation Scaling Message box appear. How to turn off this message
Permanently. Please Suggest. refer the screen dump
Thanks in Advance.
Sithick.
5 REPLIES 5
cheewec
in reply to: sast
You can set sysvar EXPERT to 5.
sast
in reply to: cheewec
Works Great !!!
Thanks a lot.
Sithick.
in reply to: sast
Has anyone found a better solution to this yet? Who do we have to bribe/threaten/plea to to get annotation scaling finally supported in ACM 20 after it was introduced? Or at least get us a sysvar to switch just this message off (the expert 5 level doesn't work either.. )
in reply to: sast
Canceling out of the message can be done with Expert 5, however to get it to work consitently you need to embed it in a LSP routine and run it in the startup suite.
;;;LSP Routine
(defun c:startup()
(command "expert" "5")
(c:startup)
;;;;LSP Routine
save above in a plain text file with extension .lsp in a support folder of autocad and then in load applications add in to the startup suite
That is still no real option, as most users actually are not expert level 5 and need all the other alerts.
Autodesk should actually do an actual update on AutoCAD Mechanical (instead of just sticking the Genius/Mechanical shell on a new AutoCAD version - regardless of the bugs - and taking the extra cash for ACM licenses w/o really giving anything back).
Annotative objects have been in AutoCAD for over a decade now, about time to support them (and Truetype Fonts, and parametics, and dynamic blocks and _paperspace_ (!!!)... you know, stuff that should've been supported already for longer then some users' ages.)
*grumbles some more*
”Boost
