When i open a drawing Annotation Scaling Message box appear. How to turn off this message
Permanently. Please Suggest. refer the screen dump
Thanks in Advance.
Sithick.
Solved by cheewec. Go to Solution.
Has anyone found a better solution to this yet? Who do we have to bribe/threaten/plea to to get annotation scaling finally supported in ACM 20 after it was introduced? Or at least get us a sysvar to switch just this message off (the expert 5 level doesn't work either.. )
Canceling out of the message can be done with Expert 5, however to get it to work consitently you need to embed it in a LSP routine and run it in the startup suite.
;;;LSP Routine
(defun c:startup()
(command "expert" "5")
(c:startup)
;;;;LSP Routine
save above in a plain text file with extension .lsp in a support folder of autocad and then in load applications add in to the startup suite
That is still no real option, as most users actually are not expert level 5 and need all the other alerts.
Autodesk should actually do an actual update on AutoCAD Mechanical (instead of just sticking the Genius/Mechanical shell on a new AutoCAD version - regardless of the bugs - and taking the extra cash for ACM licenses w/o really giving anything back).
Annotative objects have been in AutoCAD for over a decade now, about time to support them (and Truetype Fonts, and parametics, and dynamic blocks and _paperspace_ (!!!)... you know, stuff that should've been supported already for longer then some users' ages.)
*grumbles some more*
