AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Triming Steel Shapes In The Content Library
4 REPLIES 4
1065 Views, 4 Replies
Is it at all possible to trim beams inserted from the content library? I dont need the overall length shorter, I just need to cut angles. I could explode but that defeats the whole purpose.
4 REPLIES 4
Sridhar-Autodesk
You may copy the standard content to custom content folders.
Command: amcontentmanager>>From the standard content, select the required component>>Right click and Copy>>Select Custom content>>Create a new folder if required>>Paste the copied content.
Right click on the copied custom content >>edit the content and make necessary changes wrt to the geometry.
Please refer help for more info on custom content.
Sridhar Subramani
Senior Product Owner
in reply to: Sridhar-Autodesk
It doesn't seem like the most efficient method, but form what I've tried it seems like the only one. Thanks.
It would be nice if a Trim function operating the same as the Hide Situation was included. It would make it a lot easier to detail steel work.
That or be able to chamfer/fillet. It could be way more efficient.
”Boost
