AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
tool palettes
1 REPLY 1
rrowlen
314 Views, 1 Reply
tool palettes
my company just upgraded to AutoCad12 from AutoCad10.  In a effort to setup acad12, I want to make version 12 look and feel like version 10.  Here is my problem...in acad10 i have my own tool palettes that i use all the time (probably 200+ cells which are located in one folder).  It is my understanding that file from acad10 can not be used in acad12, therefore is there a way to create a tool palette (with all my dwg. cells) without having to insert each individule call into a new palette?
1 REPLY 1
Bob_Zurunkle
in reply to: rrowlen
I would think you could go into 10 and use the export feature, and then go into 12 and use the import feature, yesno?
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
”Boost
