AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Tolerance precision issue in AutoCAD Mechnical 2014
4 REPLIES 4
weiloon
824 Views, 4 Replies
HI,
My customer is using AutoCAD Mechanical 2014 and ISO drawing standard.
There is a problem when dimensioning,
according to their company drawing standard, the tolerance precision should be 4 decimal point instead of 1
For example, it should be stating as 0.2000 but not 0.2.
I think its about the setting in the zero suppression ( as per attachment),
but it is not working after changing the setting.
i tried it by using ANSI standard template,and its work.
Anyone can help and try it by using the ISO standard template ?
4 REPLIES 4
I couldn't able to reproduce it at my end. Please see attached. Can you send me a sample drawing to investigate further.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
weiloon
in reply to: weiloon
Are you using the ANSI standard? it works for me in ANSI standard but not ISO standard.
steve216586
In the box for the upper value, change the setting to be 0.2000 instead of 0.2.
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
I am not sure if it will work for you, but I had the same problem.
I tried to set up "Precision" but nothing happend as you said. But realise that there is allso effect of "Trailing" on the "Precision" and "Round off" so try to give another value of Round off it helped me.
I hope it will work for you as well.
”Boost
