AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
The application was unable to start correctly (0xc0150002)
2 REPLIES 2
eunice.chagoya
31112 Views, 2 Replies
Hello.
A couple of users are experiencing this error in Autocad Mechanical 2013 on a Windows 7 32 bit computer:
acad.exe - Application Error
The application was unable to start correctly (0xc0150002).
No .dwg can be opened derived from this error.
Anyone having an idea on what is happening? or how can we troubleshoot this error?
Thank you
Eunice Chagoya
2 REPLIES 2
This could be a visual c++ issue. Can you try the following. The visual C++ should be available in your product media or you can download from Microsoft site.
//Uninstall all VC++ versions
//Install Visual C++ 2005 SP1 Redistributable
//Install Visual C++ 2008 SP1 Redistributable
if the problem persists,  please attach the nfo file.
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Obtaini...
Hope it helps.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
Thank you.
I had to also to //Install Visual C++ 20010 Redistributable, and this solved he issue.
Regards.
Eunice
”Boost
