AutoCAD Mechanical General Discussion
Distinguished Contributor
Zoltan78
Message 1 of 4 (225 Views)
Switching to simple AutoCAD commands
225 Views, 3 Replies
07-24-2013 12:19 AM
Hail!
Is there any easy way to switch AutoCAD Mechanical 2011 to use plain AutoCAD commands in context menus (I set mouse right click to bring context menu up), toolbars (I don't use ribbon), etc.? So I'd like to eliminate all mechanical commands for good. I guess I'd need a workspace called "AutoCAD Classic" or something but there's not. I get used to simple copy command (for example) so much that mechanical's copy is quite annoying in the way that it is work. There's a lot of command like this and I don't really want to customize each one unless it is absolutely necessary.
Thanks!
Zoltan
Software: Inventor Series 2011 SP1 x64
OS: Windows 7 Professional x64
CPU: Core i7-4770K
RAM: 2*4Gb Corsair
VGA: GTX 560 Ti
Zoltan78 wrote:
 I guess I'd need a workspace called "AutoCAD Classic" or something but there's not.....
AutCAD Mechanical runs on top of AutoCAD vanilla, so there is a way to run as vanilla AutoCAD.
There might be an easy way -
Go to Start (lower left corner of screen) and All Programs>Autodesk>Autodesk Mechanical and see if there is a Run Mechanical as AutoCAD.  If so, you can right click drag adn copy an icon for starting vanilla AutoCAD to the desktop.
If not, post back for further instructions......
(or search for the instructions, as this is a common question here on the Autodesk forums).
JDMather
Message 2 of 4 (216 Views)
Re: Switching to simple AutoCAD commands
07-24-2013 05:24 AM in reply to: Zoltan78
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Zoltan78
Message 3 of 4 (213 Views)
07-24-2013 06:00 AM in reply to: Zoltan78
There's no such icon, but there's an AutoCAD icon without Mechanical! It works, thanks for the tip! I've never imagined that I should start another program.
Zoltan
CPU: Core i7-4770K
RAM: 2*4Gb Corsair
VGA: GTX 560 Ti
dgorsman
Message 4 of 4 (206 Views)
07-24-2013 08:45 AM in reply to: Zoltan78
If you investigate, you'll find that you *are* running the same program.  The shortcut which starts Mechanical loads the supporting utilities while the run-as does not.  This can be useful if you want to start out with a custom profile and/or workspace.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
