Message 1 of 9
12:17 PM
I want to draw a nut. Sweep command was used to create thread. When Sweep command was used in a different way thread visibility was differing. Drawing and Screenshots are attached.
1st Diagram
When Sweep command was used in the following order thread was invisible.
SWEEP Select object to sweep
SWEEP Select sweep path
2nd Diagram
When Sweep command was used in the following order thread has become visible.
Alignment
No
Please explain the reason for variations
