AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Standard field in BOM changed in 2012.
4 REPLIES 4
shastu
311 Views, 4 Replies
Granted I am going based off of what I saw clear back in 2008, but the STANDARD field in the the BOM changed from Height X Width to Height X Width - Length.  So if I am choosing a flat steel shape of 2 X 8 and want it 10.125 long, the standard use to be 2 X 8.  But now I am seeing 2 X 8 - 10.125.  Where do I change this format at?  I want it back to the way it was.
4 REPLIES 4
Yong.Jing
in reply to: shastu
You could follow below steps:
1, edit the steel shapes in Content Editor
2, unhide STDRT_1 column
3, edit the STDRT_1 column properties as below screenshot, Mapping Component properties to be User1
4, save and close editor
5, click Bom and setting button, and set value of User1 to be =<USER1>
6,  then you could see the User1 colum in the BOM is as what you want.
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
shastu
in reply to: Yong.Jing
I would like to keep my template consistent with what I have.  Is there another way?  What is interesting is if you look in the Family Table the STDRT is what I want, but when it shows in teh BOM it has the - length behind it.  See Screen Shots.
Yong.Jing
in reply to: shastu
The reason for this is because:
Steel Shapes Component Properties Mapping
When inserting the JIS Lip Channel Steel and JIS Gas Pipe standard parts, the BOM component properties mapping should adhere to below,
  • <Symbol of Grade> is mapped to the MATERIAL
  • Length is mapped to the dim
  • Mass is mapped to MASS  (Mass is added in the Family Table)
  • <Part Type Description> is mapped to DESCR.
  • <Standard Name> - <Part Size Specification> is mapped to STANDARD.
  • <Part Type Description> <Standard Name> - <Part Size Specification> is mapped to NAME.
You could modify the mapping rule.
Yong Jing
shastu
It seems like no matter how I try to modify it, nothing changes.  Can you give me more specifics?
”Boost
