AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Setting the Default TextStyle
1 REPLY 1
619 Views, 1 Reply
I am using VBA to create text, and also to create a new TextStyle.
I can create the TextStyle no problem. I would like this new TextStyle to become the Default TextStyle  for this drawing hereafter. Example. If I were to add new text, it would automatically be set to this new TextStyle.
I have managed to do exactly this for a Leader, but unable to do this for other text objects.
This is the code I currently have:
    Dim newTextStyle As AcadTextStyle
    Dim currTextStyle As AcadTextStyle
    Set newTextStyle = ThisDrawing.TextStyles.Add("TextDefault")
    newTextStyle.SetFont "Arial", False, False, 1, 0
    With newTextStyle
        .Height = 10 * myScale
    End With
    ThisDrawing.AcadTextStyle.Name = "TextDefault"                             'Sets the default for the modelspace
    ThisDrawing.MTextStyle.Name = "TextDefault"
    ACAD.Regen
    'Creates a LeaderStyle: LeaderDefault
    Set oDict = ThisDrawing.Dictionaries.Item("ACAD_MLEADERSTYLE")
    Dim oNewMLS As AcadMLeaderStyle
    Set oNewMLS = oDict.AddObject("LeaderDefault", "AcDbMLeaderStyle")
    ' Add the textstyle to the textstyles collection
    With oNewMLS
                .TextStyle = "TextDefault"
                .ArrowSize = 10 * myScale
                .ArrowSymbol = acArrowOpen30
                '.ArrowheadSize = 10 * myScale                              'Modify the Arrow Size
                '.ArrowheadType = acArrowOpen30                             'Modify Arrow Type
                '.TextBackgroundFill = True                                 'Fill in the back of the text
                .TextHeight = 10 * myScale                                  'Specify Text Height
                .LandingGap = .TextHeight / 2                               'Refers the spacing around the text
                '.TextLineSpacingStyle = acLineSpacingStyleAtLeast
    End With
     ThisDrawing.AcadMLeaderStyle.Name = "LeaderDefault"                    'Sets the default for the modelspace
Any help of how to get "TextDefault" as the default style for the drawing after it is created would be heplful.
As I mentioned the  code:
DOES set the LeaderStyle to "LeaderDefault." I want this, but for other text objects.
This code:
Does NOT do that.
Thanks in advance.
Tags (3)
1 REPLY 1
So I just asnwered my own question so I thought I might as well post the answer.
To set the TextStyle I needed this line:
 ThisDrawing.ActiveTextStyle = newTextStyle
”Boost
