I'm making an addin for ACM and I need to set the active layer group. The only way I've found is to use the -AMLAYERGROUP on the command line.
But unfortunately my layer group has a dot in its name. And when I set it with the sequence:
-AMLAYERGROUP _G _S BAT.A <-- My group name
ACM tells me that the group name is incorrect. If I use a group name without dot, it works. I've tried to escape the dot with a backslash or a backtick, but it does not work.
Solved by FRFR1426. Go to Solution.
Thanks but it's not me which choose the name. It's my customer. I've found a simple solution. I use the system variable CLAYER to make current one of the layer of the group.
