AutoCAD Mechanical General Discussion
Bob_Zurunkle
Message 1 of 12 (977 Views)
Sectionplane
977 Views, 11 Replies
08-05-2011 09:48 AM
Any ides as to why my sectionplane (and related) commands are not being recognized?
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
Product Support
VinodBalasubramanian
Message 2 of 12 (955 Views)
Re: Sectionplane
10-04-2011 08:35 PM in reply to: Bob_Zurunkle
Can you please tell me which command is not working and also which version of mechanical you are running at the moment and the service pack level of the product.
Looking forward to your reply.
Vinod Balasubramanian
Active Contributor
Vickimcl
Message 3 of 12 (945 Views)
Re: Sectionplane
10-05-2011 02:10 PM in reply to: Bob_Zurunkle
Hi Bob,
I found this to be a problem too and did some googling and found an answer. The sectionplane (and related) commands will not work in the Mechanical profile <<ACADMPP>> since they are AutoCAD Vanilla commands. If you load the Vanilla profile <<VANILLA>>, these commands will work. Type Options -> Profiles tab (to switch profiles)
Autodesk shouldn't have included these commands on the ribbon when you are in the Mechanical profile...I hope they read this...but whatever.
If you find having to switch between profiles annoying like I do, there is a registry fix to enable "Vanilla" commands in the Mechanical profile.
Try the following:
Click the Start menu -> Run
Type: regedit
Locate the following path:
(Note: Your path may be slightly different depending on your version of AutoCAD Mechanical)
HKEY_CURRENT_USER -> Software -> Autodesk -> AutoCAD -> R18.2 -> ACAD-A005:409 -> Profiles -> <<ACADMMP>>
On the right you should see a key called "DisableAcadSection"
Double click on this key and change the value from 1 to 0
Click OK
The next time you start AutoCAD Mechanical, the "Vanilla" commands should work.
Hope this helps.
Vicki
Patchy
Message 4 of 12 (871 Views)
Re: Sectionplane
12-29-2011 07:56 AM in reply to: Vickimcl
Thanks Vicky for the solution.
This is for you Autodesk:
If you bought a car and it doen't run like it should, you take it back and have it repair right away, not waiting a few months.
Thousand dollars people spent and get this screwed up.
Ribbon or typing in command SECTIONPLANE does nothing, no Service Pack, no HOTFIX as of today.
Bob_Zurunkle
Message 5 of 12 (867 Views)
Re: Sectionplane
12-29-2011 10:00 AM in reply to: Patchy
Yanno somewhere this all slipped past me including the responses. I have been running mine as straight AutoCAD for quite some time now, except when I need something Mechanical can do for me that nillacad can't...
Member
VIGIANG
Message 6 of 12 (789 Views)
Re: Sectionplane
09-21-2012 12:15 PM in reply to: Bob_Zurunkle
Thanks for the great infomation. Big help!!
New Member
wahyu_asus
Message 7 of 12 (680 Views)
Re: Sectionplane
01-24-2013 08:37 AM in reply to: Vickimcl
thank for suggestion. its helpful..................
MMforCMC
Message 8 of 12 (304 Views)
Re: Sectionplane
04-14-2014 08:07 AM in reply to: Vickimcl
I am sorry, but I don't understand when you say to "Run". Am I picking run or typing it? When I type regedit it asks me if I will allow changes to Microsoft Windows. Not to sure? Sorry I am computer challenged.
Type: regedit
Click OK
Active Contributor
Vickimcl
Message 9 of 12 (299 Views)
Re: Sectionplane
04-14-2014 08:17 AM in reply to: Bob_Zurunkle
Hi Bob,
Click on the start menu and type "run" in the box that says...Search programs and files
Then type "regedit"
You will get a prompt that says...Do you want to allow the following program to make changes to the computer? Click "yes".
Hope that helps.
Vicki
MMforCMC
Message 10 of 12 (292 Views)
Re: Sectionplane
04-14-2014 08:35 AM in reply to: MMforCMC
Thank you so much. I am sure that you have saved me from hours of frustration.
