I am running AutoCAD Mech 2011. When I type amscript in the command line I get "Unknown command". Any ideas why I can not run the script generator?
Solved by cmiller66. Go to Solution.
Just verifying - are you sure you're running AutoCAD Mechanical 2011 as Mechanical and not as vanilla AutoCAD? If you launch the product from the Start menu > Programs > Autodesk > AutoCAD Mechanical 2011 you'll see both options on that flyout. If you launch as AutoCAD, you'll get Unknown Command.
If you turn on the menubar: _MENUBAR 1 and then expand Tools > Script > Script Generator... do you get the same result?
Chris
I just changed my desktop. I've loaded my .fas & .lsp files into my contents suite but there's error running the script 😞
