AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Script Generator
2 REPLIES 2
3333 Views, 2 Replies
Script Generator
I am running AutoCAD Mech 2011. When I type amscript in the command line I get "Unknown command". Any ideas why I can not run the script generator?
2 REPLIES 2
cmiller66
Just verifying - are you sure you're running AutoCAD Mechanical 2011 as Mechanical and not as vanilla AutoCAD?  If you launch the product from the Start menu > Programs > Autodesk > AutoCAD Mechanical 2011 you'll see both options on that flyout.  If you launch as AutoCAD, you'll get Unknown Command.
If you turn on the menubar: _MENUBAR 1 and then expand Tools > Script > Script Generator... do you get the same result?
Chris
elaine.chan
in reply to: cmiller66
I just changed my desktop. I've loaded my .fas & .lsp files into my contents suite but there's error running the script 😞
”Boost
