Can you post the file before rescaling the object, i.e., before inserting
the scale area.
I assume you are using AutoCAD Mechanical 2005.
-Nilanjan (Autodesk, Inc.)
"jguevin" wrote in message
news:24872987.1095857673943.JavaMail.jive@jiveforum2.autodesk.com...
> We show multiple views of differing scales on each sheet/layout.
> When I create a scaled viewport of an increased or decreased scale the
"Perform Rescaling" box is checked by default. if I leave this box checked
my object lines shrink or lengthen, depending on if I increase or decrease
the scale. If I uncheck the box it works fine. Mechanical 6 didn't work this
way. I've included an attachment showing this phenominom.
