Ok, thanks. This is a known issue that we're working on. You may find that
this re-occurs if the toolbar is recompiled. There are a few alternatives
for dealing with this issue.
1. You can continue to use other methods to invoke the save (File Menu |
Save, Ctrl + S, command line QSAVE).
2. Use MENU or MENULOAD to reload ACAD.MNU (ACAD), ACADM.MNU (ACM) or
AMDTPP.MNU (MDT).
3. Use the 'Customize' option as described in the previous post from Joey.
Sorry for the inconvenience!
John
"mark-w" wrote in message
news:17324778.1092952147211.JavaMail.jive@jiveforum2.autodesk.com...
> Yes it is installed, although not being used right now, I will need some
help from our IT people to get it going.
> Mark
