AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Realistic Visual Style Problem on Paper Space
3 REPLIES 3
SamRol
1065 Views, 3 Replies
     As you can see in the attached image, in the Paper Space, depending on the visual style that I select for the viewports, the smooth of the surface is difirent.
Visual Stile
How could resolve this? I want the same smooth on the realistic Style than in the wireframe.
Kind regards
Autocad Mechanical 2011
Tags (1)
3 REPLIES 3
michaelsu
in reply to: SamRol
Normally you need to regen to get it smooth in a viewport.
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
SamRol
in reply to: michaelsu
Yes, I know that, but here it doesnt work.
Maybe I have a wrong configuration or I dont know..
Here is the file attached.
SamRol
in reply to: SamRol
I found where increase the detail
Now looks good.
”Boost
