HI,
I am having a problem whereby at least 2 times a day my autocad mechanical 2014 is crashing giving me an error as below:
'FATAL ERROR: Unhandled Access Violation Reading 0x0ab0 Exception at e93f05b6h'
The error have occured an number of times when switching tabs but other times have been completely random.
Can anybody help? I have lost so much work due to this.
Jon
Hi jhough12,
Usually, fatal error is due to:
You can apply several methods as below:
Firstly, please check below points:
Secondly, I would recommend you to uninstall/reinstall your product completely. This will mostly fix any issues from corrupted installation. Please refer to the following TS:
How to remove all Autodesk products from a Windows system
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Can you check whether you have installed a certified graphics driver. Some drivers can create such fatal errors. You can download the right one from the link below,
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
You may also want to try the following solutions and see whether it helps.
Turn off hardware acceleration,
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=5554010&linkID=9240617
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10296542&linkID=9240617
Hope it helps. Do send me a screenshot of the fatal error, if you still reproduce the issue.
