AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
RE: AutoCAD Mechanical 2014 FATAL ERROR
2 REPLIES 2
jhough12
885 Views, 2 Replies
HI,
I am having a problem whereby at least 2 times a day my autocad mechanical 2014 is crashing giving me an error as below:
'FATAL ERROR: Unhandled Access Violation Reading 0x0ab0 Exception at e93f05b6h'
The error have occured an number of times when switching tabs but other times have been completely random.
Can anybody help? I have lost so much work due to this.
Jon
2 REPLIES 2
inchul.lee
in reply to: jhough12
Hi jhough12,
Usually, fatal error is due to:
  • Corrupted installation or Windows user profile
  • Outdated graphics card driver
  • Anti-virus or security software limiting user permissions
You can apply several methods as below:
Firstly, please check below points:
  • Install the latest product updates: http://usa.autodesk.com/support/downloads/
  • Install the latest Windows updates
  • Install the latest graphics card updates
  • Temporarily disable any anti-virus or security software
  • Set UAC (User Account Control) to the lowest level
  • Disable Windows 3GB switch if in use
  • Try log in as a different Windows user account or new local administrator account
  • Try Windows Diagnostic mode (Enable Windows Installer and FLEXnet Licensing services)
Secondly, I would recommend you to uninstall/reinstall your product completely. This will mostly fix any issues from corrupted installation. Please refer to the following TS:
How to remove all Autodesk products from a Windows system
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Inchul Lee
Can you check whether you have installed a certified graphics driver. Some drivers can create such fatal errors. You can download the right one from the link below,
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
You may also want to try the following solutions and see whether it helps.
Turn off hardware acceleration,
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=5554010&linkID=9240617
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10296542&linkID=9240617
Hope it helps. Do send me a screenshot of the fatal error, if you still reproduce the issue.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
”Boost
