AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
"Shade plot" setting on viewports does not hold.
3 REPLIES 3
dalexander
2545 Views, 3 Replies
The "shade plot" setting on viewports does not hold. Once I save the drawing the shade plot setting on viewports returns to as-displayed. I like to use the hidden shade plot setting for my 3d drawings. How can I make the shade plot setting hold?
3 REPLIES 3
Chuck.Folk
in reply to: dalexander
did you ever get a resolution to this problem?
Chuck
cmiller66
in reply to: Chuck.Folk
Hi there,
I just gave this a quick try in AutoCAD Mechanical 2010 and 2011 and this is working for me.  Select the viewport > Right-click > Properties > Set Shade Plot to Conceptual or Realistic.  After I save/close/reopen and/or plot the setting still persists.
Which version are you seeing this on, and what dwg format are you saving to?  Also how are you creating these viewports?  Are these vanilla AutoCAD VPORTS, or Mechanical AMVPORTS or ? Can you attach a dwg that has this problem?
Chris Miller
AutoCAD Test Development
Chuck.Folk
in reply to: cmiller66
Using AutoCAD Mechanical 2010 and have been saving down to 2007
the command used is amvport
”Boost
