HI,
In AutoCad Mech. 2010, I draw a line 10 inches long, but when I put a dim on it, the dim comes out at 80 inches long.
How do I fix this? Some varible of 8 exits here.
Thank you,
Ken
Solved by Bob_Zurunkle. Go to Solution.
Look in dimension style, modify, primary units, then under measurement scale near the center there is an adjustable scale factor.
Still have a issue. Went into dim style and primary units. The scale factor shows (1), but the dims are still
coming out 8 x size.
Any ideas?
Ken
Hi Ken
Can you please attach a sample file?
OP for one thing I see reference to inches, units set to unitless, and dimension overrides. Try setting units to architectural and then draw at 1:1 the true length of your lines, for starters...
This wouldn't happen to be a block that was sized to fit and then exploded, would it?
THIS DWG WAS FROM A OLD SOURCE. DO NOT KNOW ITS ORIGIN. LETS JUST MARK IT CORRECTED AND
ACCEPTED.
THANKS BOB.
KEN
