Hi all.
I am trying to batch plot (publish) 90+ pages. I cannot seem to figure out how I print using the plot style I want.
Normally I would just print page to page but since this is a large one, I want to batch print it.
When I print each layout page individually it prints the way I want it using the proper Plot Style. (a form of Black & White with certain colours printings i.e company logo's). Each page is set-up with this .ctb plot style and prints perfect when I do one page at a time. However when I try to batch pot the entire file is printed in full colour. The page's themselves are proper size and centered in the proper margins, it is only the plot style that i cannot figure out. Much help is apperciated.
**EDIT** I am using 2015 Mechanical
"I've tried nothing and I'm all out of ideas." - Nedward "Daddio" Flanders
Solved by newbies. Go to Solution.
The key to having all pages in a publish job processed uniformly is to apply a page setup. A few years back, I recorded a short, narrated video for a support case, in which I demonstrate how to apply a page setup to all the sheets in a publish job. Although I used AutoCAD 2010, the concept still applies. You can view the video by clicking here. Please post back here and let me know how this works out for you.
How About this? Let me know if that's working or not.
I have tried with no results. In paperspace I typed PAGESETUP and created a new Setup. I chose the plot style I wanted and click PREVIEW. The PREVIEW was exactly what I wanted. I exited, then I typed in PUBLISH. I made sure the Layout with the PAGESETUP I just created was at the top of the list. I highlighted all Layouts and Chose the New Setup. I went to PREVIEW and it is not choosing the proper plotstyle even though I am in the right setup and the plot style is assigned to that setup.
I have actually Printed and it Prints in all colour (so the PREVIEW is correct). When I go Back and just print single pages, they print the way I want them too.
Hye Ryan.Irwin.
Let's try it again...
1. After finish Figure 1,2 & 3 (As I post before), try to save this drawing file before proceed to publish.
2. Base on figure 4, before you add another drawing, make sure you already set the "Page Setup" to what you choose. Then Save first (refer to figure 4, save button located at top-left, next to sheet list.
3. Then, add another drawing in.
4. After another drawing added, select all then choose Sheet List (Top-Left) to saved file as where step 2 is.
5. Then Publish.
Let me know if that work or not. I haven't problem about this publish...or may be I explain to you not too details.
Thank you!!!!!!!!!!!!
I had to Save the SHEET LIST then it worked. Thank you so much time helping me on this +1
