Just started an account on here because I am curious if others are having similar issues. We use Autocad Mechanical in our shop , and just downloaded to the 2014 version. I am unable to figure out how to get the properties pallet on the home ribbon. I use a 2014 version in my Autocad class and it has the properties pallet but when we did the download at our shop neither computer had the properties pallet which is much quicker than using the properties manager that you can bring up and take up way to much room on the side of the screen. Just a little input would be nice.
Thanks Casey@ Worksaver Inc.
Let's try this out:
Type CUI in the command line.
In the Customize tab, scroll through the All Customization files for Panels. Open Panels and scroll down until you find View - Palettes. From here, there are several ways to do this, but you should be able to drag and drop (or rt click Copy) the View - Palattes to the Home folder (located in the Tabs folder - which is located in the Ribbon folder). Click Apply and this should appear on your home tab.
While you are in your HOME tab, go all the way to the right top of your workspace and right click in the empty gray area. This should open a menu list fly-out. Hover over the "Show Panels" bar and another fly-out will appear. Check the box for PROPERTIES.
