Hello!
My problem:
I crated new drawing. I saved it. Closed it. When I open again there is error like this (see attached). Every time.
I can click NO then I can add something but when I will save drawing and close and open again drawing is blank!. Then I have to use recovery drawing then everything is ok. Or when I click NO I use AUDIT command AC find 1 error (I don't know why) I save it and it is ok.
But why everytime is error? In AC Mechanical 2010 everything was ok. No errors.
I installed Service pack 1, but nothing changed...
Hello.
I have lot of drawings made in AC Mechanical 2010. When I open them and save and open again everytime is error. I tryed save like a AC Mechanical 2010 dwg, AC 2010 dwg, AC Mechanical dwg 2015. Still doesn't work...
I see a same issue before, in Autocad.. can you try the below and see if this works in this situation.
http://forums.autodesk.com/t5/AutoCAD-2013-2014-2015/Error-opening-drawing-every-time/td-p/3457610
Sorry there was extra space at the end of the url. please try again.
